Lead adapter question
  • Thread starter Thread starter marsaday
  • Start date Start date
M
marsaday
I am fitting a new toilet and i want to tidy up the pipe work behind it.
I would like to extend the copper pipe to the left and site the stop tap on this side of the toilet. Can i easily undo the nut on the lead adapter where it hits the first tiny length of copper and then replace this with a good length of copper of about 50cm? I dont think this nut has been touched for yrs and so i am not sure if i remove would i be causing trouble for myself.
I do know the stop tap was added 3 yrs ago as the old one was weeping, but that small length of copper was left as it was.
View media item 60006
Yes you can extend the copper but get a good grip on the central nut shaped part of that leadloc before undoing the smaller compression nut.
Can you shut the supply off before that point?
Yes i will shut the supply off in the street first. Will i need a new brass olive as well
