I have a bathroom tap which has a slow dripping leak. The leak seems to be coming from a connector joning the steel hose to the plastic pipe.
This affects only the cold side. The hot side is not leaking. For the meantime, I have closed off the supply to the cold side by using a screwdriver to close the cold globe valve.
My questions are:
* What could be causing the drip?
* What steps should I try to fix it and what tools will I need for this?
My questions are:
