Hi
I've had a problem with a bathtub leaking into the ceiling below.
I took off the front panel and tested - water stays in the tub when the plug is in.
When the plug is removed, the water leaks out of the bottom of a black pipe (might be called the overflow pipe) near where it is connected to the waste.
It leaks when there is only a very small amount of water coming through (so it might be at the bottom of the overflow or where the overflow joins the waste (not sure)
It's quite hard to do/see much as the space under the bath is small.
Is it possible to :
a) fix this without removing the whole bathtub (which is sealed in)
b) fix this by one's self. If so how?
c) or if one called a plumber, would they have to take out the whole bath?
Thanks for any advice!
Jobby1
Is it possible to :
Jobby1
