leaking CH pipes under cement floor
26 Nov 2007
Buckinghamshire
Good morning all,
We suddenly noticed in our 1967 bungalow that a leak developed in the CH pipes burried in the concrete floor at two places, bedroom to corridor line.
The carpets were found wet & so the concrete floor under them, and same wiith the near by lower walls.
The CH header tank looses about 2-3” of water in 24 hrs.
The radiators installation is the original of a single pipe type, with a shut of valve only on one side.
It was powered from a conventional system in the utility room, which was done away with to enlarge the kitchen 6-7 yrs ago.
Since then the above system is powered by a Potterton Kingfisher M F 60 boiler, with an “OSO” Unvented Water heater, Indirect 250 & new header tank, all istalled in the garage.
Is there a way to abandon the old piping system & install new pipes above ground?, and if so which would be the most economical way.
Nick
Install a drop system!!
Depending on how many rads and their location £750-£1250
Thanx Gents,
I will have to accept the cost as is really a catastrofic fault. Are all the bangalows saffering this after 30 yrs.? or am I just the unlucky one.
Can you give me some clues &/or tips of how the "drop pipe" system chould be done.
Nick
Surely repairing the leak would be covered by your household insurance, if it is see if you can negotiate with them to cover part of the cost of renewing the pipes.
Nick
if its a one pipe system, then i think you may be able to trace the pipes between each radiator, chop them off at each leaving tails then simply take a new pipe from one tail to other, but surface mounted. i hope that made sense!
If you do try the insurance company tell them it was since you were carrying a heavy safe and it dropped near to the pipes or something. If you cant construe it as 'accidental damage' they will wriggle out of it.
This means installing the complete pipework system in the roof space and dropping the pipes down the walls to where the radiators are situated.
I doubt if you will want surface mounted pipework though.
So one option is to chase the walls and place the pipes in these channels.
Is the existing pipe work copper or iron ?. Is it definitely a one pipe system ?.
I'd go the floor option and hire something like this in a for a few hours and chase the entire floor for the new pipe runs. ( If indeed the system needs re-piping)
You might want to vacate the premises though. :LOL:
The CH header tank in about 2m above loft floor.
If a ring of pipes is layed in the loft floor to distribute the downdrops to all the rooms below, will the 2m header be enough, or do you think I will have air geting in the pipes or something.
If so, is there anything else I can do to prevent it, as I cannot raise the header tank any more.
The system is powered by a Potterton Kingfisher M F 60 boiler, with an “OSO” Unvented Water heater, Indirect 250 & new header tank, all istalled in the garage.
