    Dismiss Notice
leaking lockshield valves on towel radiator
Discussion in 'Plumbing and Central Heating' started by makemray, 2 Sep 2013.
  1. makemray
    makemray
    2 Sep 2013
    2
    Thanks Received:
    Country:
    Hi, I was going to drain my central heating system in order to fit some new thermostatic valves downstairs.
    Before doing so I was checking my valves upstairs to make sure all were free etc. The combi boiler and electrics were off. When I went to close off the towel warmer radiator in the bathroom I noticed that water slowly leaked from the two valves as they closed . It continued until I opened the valves.
    I am guessing this should not be the case ! It also reminded me that I have had an unsolved slow loss of pressure on the boiler for some time. As this is the systems open radiator (i.e. not controlled by a thermostatic valve ) could this be the cause of the loss of pressure. Not noticed water leaking from there before but that could be due to this radiator being the constant hot one and small leak would just evaporate.
    Or would you expect those valves to leak slightly when closed off while system still under pressure.i'e' I had not released the bleed valve.
    Wondering if the valves need replacing although not that old !
    cheers
    Ray
  2. 45yearsagasman
    45yearsagasman
    14 Mar 2010
    6,085
    Thanks Received:
    1,091
    Norfolk
    Country:
    Depending on the type, it may be possible to remove the knob and tighten the hex nut slightly in order to compress the seal around the spindle.
  3. Sponsored Links
  4. makemray
    makemray
    2 Sep 2013
    2
    Thanks Received:
    Country:
    The leak seems to be from the thread of the valve nut.( I.e what turns to shut and open valve. Not sure I know what the you mean by the knob ? I can access the hex nut will that solve what I describe ?
  5. Madrab
    Madrab
    4 Oct 2012
    7,715
    Thanks Received:
    2,158
    East Renfrewshire
    Country:
    it might, give the nut a little tweak clockwise and it may seal it up
    • Thanks Thanks x 1
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
