Apologies, I'm sure this must have been covered but I can't find it!
We have a Wickes frame-less shower and water is leaking from the door. Investigation shows the problem is water is running down the door, getting into the strip at the bottom and then running out the end of the strip, bypassing all the seals!
We've tried a blob of sealant on the ends of the strip but the problem remains.
I'm guessing a better seal between the strip and the door is needed, obviously I'm not going to run sealant on the door so I'm not sure what to do...
The strip on the door came with the kit and looks like an H (with splayed bottom) so I think it's the right strip...
Any suggestions would be gratefully received!
