Leaking Shower Tray Join
12 Dec 2006
Derby
On moving into my house a few months ago, I noticed the tiles around the newly fitted shower/shower tray were discolouring, and the silicone was coming away. I removed the old silicone and started to take out the grout which was soft, and lifted up the tiles. Underneath was drenched with water, so i cleaned up all the grout and left the base to dry out.
Once it had dried out, I applied new unibond waterproof grout/adhesive and re-layed the tiles. Once these had dried I re-sealed the edges to the shower tray and walls.
This monring I noticed the silicone coming away, so I pulled it off and the tiles moved, so I lifted them and again it is covered in water.
Any ideas how I can permanently seal the tray and stop the water getting through to the grout/adhesive underneath?
Sharon
What are the tiles onto? Plasterboard, plywood etc?
Most likely your shower wasn't tanked(?)
The tiles are onto a wooden base, like a thick plywood. The water has soaked into a small part of it where it has started to crumble like a plywood. Havn't a clue what tanked means, so probably not looking at all the other corners that have been cut in this house.
Any ideas what I can do to sort this out?
Kind regards, Sharon
Unfortunately only cowboys tile on plywood. They should have used Aquapanel.
I thought as much, you wouldn't believe some of the work that has been done here. Is there any way around it without taking the whole thing out and starting again?
Not really :cry:
Do a search on Moz's post for tanking shower, plenty info there
I didn't tanked my shower, but used shower panels which is similar like this
Excellent link , Masona....I`ve used Marbrex panels before :idea: similar stuff
Can someone tell me where Moz`s article is on this forum re this subject
Only cowboys tile on plywood? what about plasterboard ? does everyone need to rip their bathroom apart to tile on "Aquapanel" I guess it makes me a cowboy for tiling onto plasterboard? THANKS FOR TELLING ME
