My shower has started leaking, sending water through the floorboards and damaging the ceiling of the floor below. A plumber said water was running off the top of the bath and down the outside. At first that seemed plausable, as water does tend to escape a bit.
To cure this I went around each edge with silicone sealant. Did not work and there really don't seem to be any gaps. Also, the leak is intermittent. To me it seems like there is a leak where the hose of the shower meets the wall. [shower is mounted onto a plasterboard stud wall, with plumbing passing through the plasterboard and then down to the floorboards]. Yet the hose seems firmly fixed to the tiles/plasterboard. Maybe it isn't on the other side?
It's an Aqualiga shower and I wanted to get an opinion before I started taking the shower down. Not even sure if there is any way of getting access or whether the unit has been built in, as the bath and shower were fitted when a builder re-furbished and re-configured the bathroom.
