Hi everyone.
I need you advice with this combi i've inherited, as just moved in.
Over the past couple of days i've noticed its been leaking. I have removed the cover to take a look.
I have found the leak which i think is on the diverter assembly. I'll describe it to make sure. Its on the left hand side and attached to it is a metal 'fulcrum' bar which in turn is linked to a larger assembly.
The leak is at the top of this assembly. It looks like its held in place with four screws. I'm assuming that there must be a seal/gasket/washer behind which has perished. There is no water dripping from the central pin.
I have drained the system down ( installing a new rad anyway). Could someone tell me what part i need and should i replace the insides of this diverter at the same time.
PS: I tried tightening the screws but it didnt work
Mark
Mark
