I recently replaced the flush valve in my cistern because the previous one (pretty old) began leaking a constant trickle of water from the cistern into the pan. I bought a fairly standard one from Wickes (push-button dual flush with a cable, internal overflow) but, having fitted it, it appears to have the same problem. I fitted it using a close-coupling kit with a rigid plastic plate fitted to the underside of the cistern. The backnut is screwed up very tightly using the spanner provided. Also, when the water level in the cistern falls below a couple of cm, the trickle stops so I’m pretty sure that the leak isn’t from the sealing washer but from the valve itself.
Any ideas or did I just buy a dodgy valve ?
