Hi about a month ago the cold water tank was leaking and my trusty plumber kindly replaced the ball valve which appeared to fixed the problem..... i saw the old one that was removed and it looked a bit crusty!!
was away for 2 weeks and it appears all was still well and no leaky pipe
It has now started leaking again
however once i run some water it stops it for a while
The hot water tank has also had its ball valve replaced in the last year
I also get some noises from the ch pump unless i turn it right down(but then the radiators downstairs are cold) dont know if this could be linked
Now i am hopless at DIY but after reading some threads here about lowering the water level i might give that a go
How is this done and is there owt else that can be checked while i cripple myself lurking in a junk laden loft
i have my boiler and controls being serviced shortly by BG as part of homecare package how much would it cost for BG to fix this problem?
Thanks in advance....
