leaky radiator
  • Thread starter Thread starter BD
  • Start date Start date
BD
15 Aug 2008
Northamptonshire
the radiator in the bedroom is leaking, I have got a new air valve as I thought that was the problem but on closer inspection the fitting has corroded. Can I patch it up or is it a new radiator I will need?
The bleed fitting is usually brass.
Its usually the steel surounding part of the rad which has corroded.
However, its often possible to make a water tight seal with a new brass fitting although some skill is often need in using the right jointing material.
Anyway a new rad is usually no more costly to buy than a weekly tankfull of petrol.
Tony
The bleed fitting is uaually brass.
i think you will find they are very rarely brass.
a replacement may well be.
there is no point generalising on the cost of a new radiator.
I agree. I ain't seen many rad valves made of brass(don't think I've seen any) and, Ive fitted one or two in my time.
