Led dimmer on dual switch circuit
21 Jul 2010
Weymouth, Dorset
Two light switches in hallway operating hallway lights, can I put a dimmer on one of those and dim the lights?
Yes, you can get a 2 way push on/off dimmer ( most are nowadays} and keep 1 switch, or a more tricky option is a slave and master, which will dim from both positions, but you may need to shuffle the wires round which is not always that simple.
Be carefull that the Dimmer and Led lamps are compatible with each other
