LED fittings
1 Dec 2006
Cumbria
Should new LED light fittings have built in components to combat glowing when switched off due to induced volts or capacitive coupling.
They should.
But not all do.
Signifies manufacturers are reluctant in spending a very little amount in including a RC snubber circuit.
BTW, you can reroute the wire so the switched live and the incoming live does not run parallel for too long.
That commonly happens as far as this problem is concerned.
