LED friendly motion sensor
1 May 2012
Hi
Can someone please recommend a PIR motion sensor that would satisfy these conditions, in order of importance:
- Works with low power led
- 180 degrees horizontal detection area
- Wall mounted, preferably on a 16mm single gang switch hole
It would be nice if it also has a photocell to suppress during daylight.
The nearest I found was this: http://www.timeguard.com/products/light/automatic-light-switches/motion-sensor-pir-light-switch but it isn't very clear about low power, it states "15 – 150W electronic PL lamp (Philips or Osram only)" which I am not sure would work with something like 1 to 4 LEDs of 5W each.
Then this http://www.bestofferbuy.com/TwoWire...ce=gbase&utm_medium=cse&utm_campaign=gbase_uk promises to work with LEDs but only covers 140 degrees and isn't adjustable which isn't going to work in my case, not to mention that the emphasis on the two wires is a bit weird.
I also found this: http://www.astra247.com/5075/Lighti...ion-Detector-S-or-Steel/Infrared-Wall-Sensor/ but I can't find any confirmation that it works with LEDs or any low power bulbs.
