I recently had to replace an LED spot light, just a cheapo one from SF (not LAP though !):
https://www.screwfix.com/p/luceco-slimline-led-floodlight-black-10w-1050lm/714kj
I have an outbuilding, SWA runs from a House CU for approx 10-15 mts, terminating in a wiska box in the outbuilding.
Running from a spur on a single pole socket in the outbuilding, when turned off, and it was dark, you could see the LEDs glowing very very dimly. It would turn on OK at the switch. After about18 months the lioght failed to operate at the switch.
Could there be any form of induction or other way that power is leaking. I have checked the voltages coming into the outbuilding, and there appears no leak across N and earth. Polarity all looks good.
I have a new light I need to fit, I should fit that - could it be a duff light ?
Bit miffed if anyone can help.
