LED's
22 Aug 2013
Essex
Hi Guys & girls, I need some advice. I need to put some flexible strip LEDs in a cupboard.
I need them to light up when the cupboard door is opened.
The LEDs are powered by a 12 volt 5Amp AC/DC Adapter.
Input 100-240 Volts 50/60 Hz 1.6 Amps
Output 12 Volts 5 Amps
Is it a bad idea to
1. Have the adapter permanently hard wired into the mains and have the switch on the output side of the adapter so the lights come on when the door is opened?
Or
2. Should I put the switch on the input side of the adapter?
If, as I suspect, option 2 would be preferable is there a fridge door like pressure switch you can recommend to handle the 240 volt feed to the adapter?
You’ll get very little useful help or advice here my friend. Most of the replies you’ll get if any will be from electricians telling you you’ll need an electrician!
Switching the 230 volt with one of the door switches such as these
http://www.tlc-direct.co.uk/Main_In...tches_Mini_Index/Switches_Miniture/index.html
There are other suppliers
Naturally it will have to be done safely to BS7671 standards.
Spanish standards do not apply in the UK
Is it a bad idea to ...
1. Have the adapter permanently hard wired into the mains and have the switch on the output side of the adapter so the lights come on when the door is opened? ... Or
As you surmise, option (2) is probably the way you want to go. There are plenty of 'door switches' around designed for this very job. I'm not in an immediate position to find you any links to suitable products but, if no-one else jumps in, I'll see what I can find later.
Kind Regards, John
That is a very unfair generalisation, and is also factually incorrect. The person in this forum who is easily the most likely to give a "you need an electrician" reply is not an electrician.
Kind Regards, John
Is it a bad idea to .. Have the adapter permanently hard wired into the mains and have the switch on the output side of the adapter so the lights come on when the door is opened?
Or ... Should I put the switch on the input side of the adapter?
Yes and yes.
The switch shown by Bernard is what you need, but mount it as close to the hinged edge of the door as you can possible get it - the spring is surprisingly strong, and you don't need to allow it much leverage for it to push the door open, unless it has a proper latch. If it's just got spring hinges, or a magnetic catch the switch will open it unless it is close to the hinged edge.
You'll need a fused connection unit upstream of the switch as it can only take small cables.
