Had the dreaded ignition lockout a couple of times randomly recently, but it's never done it when I've been watching as I've been trying to determine if it happens pre or post ignition.
I've been monitoring the startup pattern... heating on, pump starts, fan starts, air pressure switch clicks, gas valve/relay louder click then a few seconds later the flame ignites.
However, I've noticed that the length of time between the gas valve click and the flame appearing seems random, anything from instantly to several seconds. What is the cause for this delay? I'd have thought as soon as the ignition PCB opens up the gas it would ignite it at exactly the same time every startup.
It's a Halstead Best 50. New gas valve/ignition PCB 12 months ago. New aquastat PCB, thermistor, flame sensor and ignition cable 4 months ago.
Last time I got the ignition lockout, turned out to be a sticking gas valve which was why that and the PCB were replaced 12 months ago, but when that happened the boiler tried to light several times before giving up and locking out. This time the lockout seems to happen almost instantly and straight away rather than after a few retries.
But back to my original question... is the fact that the flame lighting can vary from 1 second up to a few seconds a clue or a red herring?
