Any suggestions please...
Some background first....
Old 1900s house
Small bathroom approx floor area 2.5m x 2.5m
Floor is floorboards with plenty of gaps
Rental property being tidied up after long standing tenant has passed away
Will be re-rented
The bathroom floor was carpeted but it was obvious that the toilet was on a large plinth with the carpet over it. I presumed the plinth was there because the hole in the wall for the toilet waste was too high.
Have removed carpet and found that the plinth is there because the floor has dipped badly. No rot, just age. It is probably down by 1.5" or so.
It is all quite strong and firm. Boards need local attention.
I really do not want to embark on bath out and all boards up so want to do something on top if possible.
Am considering tightening all boards and replacing bits where required. I am confident the floor will then be quite solid. Then cover the whole with a thin WBP ply to get a reasonable surface without being much higher than the outside of the bathroom. Then make up the lower area as required with more ply, then skim over with a flexible self levelling compound to around 5mm.
Not looking for perfection, just a reasonable surface that will take a vinyl finish without knowing the toilet is on a plinth.
andytw
Old 1900s house
Will be re-rented
andytw
