LG WM-1280FHD Washing Machine problem...
11 Feb 2007
Warwickshire
Hi all,
I've got a poorly LG WM-1280FHD.
Basically, it fits and starts when trying to rotate and makes a sort of metallic 'hissing' sound from the motor.
There is no adverse sound when rotating the drum manually and it seems perfectly smooth.
After about 6-7 minutes it gives up and displays the fault code 'LE'.
Can anyone give me a couple of pointers as to what to check ?
I initially thought bearings but like I say it's smooth when rotated manually and it's had a very easy life since I bought it four years ago (1 or 2 loads per week max).
I'm now thinking perhaps motor or PCB but is there any way I can check ?
Thanks in advance.....
You need to check the motor brushes but if they are OK it is likely that the motor is faulty and the noise you are hearing is the motor sparking.
