    Dismiss Notice
Light fitting with no earth
Discussion in 'Electrics Outside of the UK' started by adrienne224, 27 Oct 2017.
  1. adrienne224
    adrienne224
    27 Oct 2017
    Thanks Received:
    Country:
    United States
    I've just about to replace a standard light pendant with a new (fancier and metal one) and noticed that the new fitting has no earth connector. I think it doesn't need one as the Live and Neutral wires are double insulated (within rubber sleeves and in a plastic connector box). If that's the case do I just tape up the earth wire and leave it in the ceiling ?
    This is probably a daft question but I want to make sure I do the right thing !
  2. Sponsored Links
  3. JBR
    JBR
    9 Jan 2007
    8,893
    Thanks Received:
    389
    Cheshire
    Country:
    My advice is to put on your steel helmet and prepare for the in-coming!
    In fact, I'm surprised no-one has fired a few shots over you bows already!
    Anyway, trying to be a little more helpful, electrical cables are not 'double insulated'. It is the light fitting that needs to be double insulated, and if you can see a symbol of a square box inside another square box, you're OK. If not, a metal light fitting must be earthed and really ought to include some means of attaching the earth cable.
  4. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    I didn't realise that you were knowledgeable about what the NEC says about this. o_O
  5. JBR
    JBR
    9 Jan 2007
    8,893
    Thanks Received:
    389
    Cheshire
    Country:
    We live and learn!
  6. JBR
    JBR
    9 Jan 2007
    8,893
    Thanks Received:
    389
    Cheshire
    Country:
    If you still haven't left us, Adrienne, may I ask where you bought the light fitting?
  7. JBR
    JBR
    9 Jan 2007
    8,893
    Thanks Received:
    389
    Cheshire
    Country:
    She's gone!
    Why do people come here looking for advice and then just bugger off? :confused:
  8. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    People are allowed weekends off.
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
