Light not turning off
9 Oct 2009
Cambridgeshire
I changed an old 3 way light switch in the hall way. It controls 2 lights in the hallway and 1 on the landing.
The landing light now will not turn off.
If I disconnect from the 3 way switch and just use one of the 2 single switches on the landing it works fine.
Sorry for the bad terminology and description.
Any help would be greatly appreciated.
Thanks.
How it should be wired if following normal convention is one cable for each light and normally there is a slash across back of the switch defining each switch within the three gang unit. As long as one wire of each cable goes into com and the other into either L1 or L2 it should work.
However still within the regulations many things are done including sharing a feed wire. Once one leaves normal convention then testing is the only way forward.
All I can suggest is a picture of back of switch. We may see something which shows us what is wrong. Try to show wire groupings i.e. which wires go into which cables.
Also back of switch so we can see markings. Some switches don't mark as Com but mark the same terminal as L1 makes it easy if we know how it's marked.
