I was going to use lamps at the side of beds and a R/C main light switch. That would be quite good I think, as bed may want to be moved at some stage I guess.
Cheers mate, I know GET are quite good. B&Q do r/c units by Homeserve which has a digital/lcd remote controller and a base where you can text commands home if need be. Do you think these are as good as GET?
True, but Im having lamps either side and a main light also, so should be enough. My sparki suggested having downlighters and a main light in the middle, has anyone else dont this. He explained that they recently done a job like this and it looked quite effective.
