    Dismiss Notice
Light weight windows for a metal shed?
Discussion in 'In the Garden' started by BML, 14 Apr 2021.
  1. BML
    BML
    12 Aug 2004
    87
    Thanks Received:
    2
    Country:
    I have just erected a metal shed or rather my grandson did it for me and I'm rather worried regarding it over heating as I'm using it as a Hen house. One way to control the temperature would be to install a window either side of it but as a result of the frail nature of the structure it can only accept something very light. Can any one suggest where such items would come from?
  2. Sponsored Links
  3. scbk
    scbk
    22 Dec 2012
    891
    Thanks Received:
    168
    Ross-shire
    Country:
    For a hen house you need permanent ventilation - start cutting some holes!
  4. BML
    BML
    12 Aug 2004
    87
    Thanks Received:
    2
    Country:
    The shed is well ventilated and I still want to fit a couple of windows.
  5. big-all
    big-all
    12 Jul 2004
    18,751
    Thanks Received:
    1,464
    Surrey
    Country:
    do you have a picture off the shed ??
    you may find that a framework off some sort will be practical to help both wall strength to fix a window too and also space for insulation installation??
    and although small heat input lighting and bodies [pets ]do count to the heat input level
  6. Alastairreid
    Alastairreid
    21 Nov 2008
    6,652
    Thanks Received:
    1,081
    uk
    Country:
    Perspex.
  7. BML
    BML
    12 Aug 2004
    87
    Thanks Received:
    2
    Country:
    I looked for a window on ebay and I thought I had found one as the page was covered with pictures of wooden windows but a sheet of Perspex turned up so I'm still looking.
  8. big-all
    big-all
    12 Jul 2004
    18,751
    Thanks Received:
    1,464
    Surrey
    Country:
    i assume they would use words like "glazing" and "instead off glass" rather than window as window is the whole thing including frame and glazing :?::?:
  9. BML
    BML
    12 Aug 2004
    87
    Thanks Received:
    2
    Country:
    The above picture is of the sort that the Internet is full of which intimates that the item is a window frame and a piece of acrylic and not one of the advertisers that I have contacted actually sell window frames.
  10. Sponsored Links
  11. big-all
    big-all
    12 Jul 2004
    18,751
    Thanks Received:
    1,464
    Surrey
    Country:
    the picture is for context an actual window would have several connected questions to do with openers and type as well as number
  12. BML
    BML
    12 Aug 2004
    87
    Thanks Received:
    2
    Country:
    What a most helpful reply!
  13. big-all
    big-all
    12 Jul 2004
    18,751
    Thanks Received:
    1,464
    Surrey
    Country:
    not sure what to make off your comment
    i am trying to be helpful as in all the emphasis is on glass [plastic size ]where as if it was a full window the questions would be about the makeup off the window as the glazing is secondery would get a breif description as in 3mm clear polycarbon
    • Like Like x 1
  14. BML
    BML
    12 Aug 2004
    87
    Thanks Received:
    2
    Country:
    As far as I'm concerned the pictures of a window that I saw were just that a WINDOW yet not a single one of those who used it are actually offering WINDOWS. I reject your statement that the emphasis is on glass especially as its actually Perspex. Anyway, I'm still looking for a window.
  15. scbk
    scbk
    22 Dec 2012
    891
    Thanks Received:
    168
    Ross-shire
    Country:
    Would a window not make the shed hotter by letting in sunlight?
    If you want an opening, cut a hole and have a bit of plywood/rigid plastic or whatever on a hinge. You could even use a greenhouse auto opener. You would probably need a basic frame round it to strengthen the shed.
    I've never had a problem with a hen house overheating, and I've never fitted a window to one
  16. Captain Nemesis
    Captain Nemesis
    8 Jul 2020
    3,040
    Thanks Received:
    99
    Country:
    I'm confused...
  17. Captain Nemesis
    Captain Nemesis
    8 Jul 2020
    3,040
    Thanks Received:
    99
    Country:
    From the following?
    1. Aluminium channel or angle
    2. Hinges
    3. Sheets of acrylic
    4. Tube of sealant
    5. Hacksaw
    6. Drill
    7. Pop riveter
Loading...
Share This Page
