Hello.
Prior to an EICR - all the accessories were checked for their tightness of cable clamp screws, and their general condition, signs of arcing etc., Nothing of note was found.
The property is a 3 storey Semi, TNS, 17th Edition CU, split with two RCDs.
Sockets on rings, lighting on loops - one for each floor.
Outbuilding on 4mm SWA to its own CU.
The EICR was performed and passed, within the previous certificates recommended date interval.
Since I had been focusing on the Light fittings for several hours - I noticed a very faint flicker in the lighting circuit when lights are turned on, this flicker has a rhythm, the flicker occuring every - 5-10 seconds, with a an even fainter percussion of flicker straight after. You would hardly notice it unless you stared at it. It may have been there well before the accessories check - and EICR, and not noticed..
The Light fittings have LEDs fitted.
I will try isolating each circuit in turn to see if one particular circuit, or combination of circuits is the culprit.
In the meantime - any thoughts.
Thanks.
Thanks.
