lighting
5 Aug 2007
Middlesex
after installing new light fittings and turning on the power there was a flash and the lights went out. now none of the lights on the ground and first floor work yet the lights on the second floor work, could it be a blown fuse? if so why did it happen could it be dodgy wiring by myself
yes.
blown fuse tripped mcb.
i bet you put all the reds with the reds and all the blacks with the blacks
its a common mistake.
lots of posts on here about how to do it right, also drawings in wiki and sticky forums
And if you have ****ty light switches.......it can confuse even more, as once you have actually wired the light correctly......the switch then doesn't work :lol:
