Evening all
I have a house built out of red brick in 1896 and I need to build an external section of wall where I am blocking a doorway up. The beds on the building are tiny (maybe 5mm) and the original mortar is quite a dark grey, almost charcoal. I suspect when the house was built they used lime and a coarse dark sand.
If I build this section with a dyed sand and cement (it is about 1200mm square) is this likely to cause any problems? Am I better using lime mixed with a dark grano instead of cement?
D
D
