To all,
I have taken the lining paper off my internal front elevation around the front door. The lining paper had been stripped but I have left a small amount about 10mm from the corner of each side wall (the side walls have lining paper on).
I need to reline the front elevation so do I cut the existing Lining papaer back all the way to the corner of leave it 10mm in and paper from there?
If I leave 10mm of paper I can cut it straight using a level and then repaper up to it. If I cut back to the cornetr the walls are prob not straight.
Hope this makes sense?
Cheers,
Dan
Cheers,
Dan
