live earth
21 May 2004
I have found on my ring main ciruit that the earth wires are live. I have been trying to illiminate the problem, but have found that my meter is buzzing between the main earth cable and the main neutral cable, is this ment to happen???
meter is buzzing?!
get a proper meter and get us real readings
it sounds like your main earth may be disconnected
Not to sure what kind of readings i should be looking for!
Because my ring main keeps tripping i am told that it is likely to be a faulty leg. I am then told to check each leg, one at a time to find the problem. What setting should i have my meter on and what reading should i be looking for??
sorry correcting my original answer
when your meter was buzzing was it in continuity mode?
if so then it is expected for this to happen between main earth and neutral
mutimeters are fairly complex equipment and you really need someone to show you what the different functions on it all do and how to use them
Is it ohms I should be testing for?? Im told that each leg should be about 1 ohm, and anything above 4/5 is likely to be the leg with the problem...
That sound right???!!!!
depends where you are metering. sorry if i appear vague, its just that you can say any reading you like, but it depends on WHAT you are checking as to its reading
And when you say "my ring main keeps tripping", what do you mean? Is it the circuit breaker for the ring, or the RCD?
Does it happen when everything is unplugged from the ring?
Had you done any electrical work just before this started happening?
Bought any new appliances, or started using one you've not used for a while?
Done ANY drilling/screwing/nailing anywhere?
