Neutral and Earth continuity.
15 Dec 2009
Essex
Hello All,
I have found that i have continuity between the earth and neutral wires on my downstairs ring main.... Is this safe? Should i get someone in to look at it? I'm thinking it shouldn't be like this in case of a live to earth fault.....???
Any ideas?
Thanks,
Andy.
P.S. it's in a victrian house with old red/black T+E, probabley retro-fitted many many years ago....
Yes, still connected to the CU, I have just split the ring to put new sockets on and thought i would just check the wires as i don't have a CU with RCD's in. Interesting this is that there is only continuity between N and E on one side of the ring...?????
did you disconnect all the live (line) and neutral conductors or just pull the fuse / switch off the MCB??
have you got continuity beteen line conductors
have you got continuity beteen neutral conductors
have you got continuity beteen CPC conductors
the reason i ask is that if it is a 'ring final circuit' and you have split it at one place you should be getting the continuity from neutral to earth on both cables.
the reason you are getting continuity is because you are reading back to the star point of the generator / transformer.
Thanks for the info, so what i am seeing there is ok then. For some bizarre reason i did not check the continuity of connections around the main, will look at that tonight.
The reason for posting is that the ring main now works ok by splitting as a spur in each direction but pops the fuse when connected as a ring....???? I just assumed i had some kind of earth leakage from the N and E contenuity. Have you come across this before? Thanks. Andy.
possibly, but you need more information to be sure.
Is it a ring?
What size fuse is protecting the circuit?
erm, what do you mean :-
you've got two cables, when seperated they work, when together causes fuse to go?
Doesn't sound safe so far.....
