LIVE live, LIVE neutral, LIVE earth all showing current??
1 May 2005
Lancashire
Hi, just tried to replace a single switched socket (because the switch had locked up)
2 x twin + earth going in. ALUMINIUM so not sure what mmsq
Found that all 3 wires in one cable are showing live, the other is ok.
Socket appeared to be on a ring main, (1 in 1 out)
But could be a spurred spur? as no other sockets were known to go down went disconected.
Socket and system have probably been like this for years and the only known problem is a very sparky clicky heater control clock, thats prob totally unrelated
Hows the neut + earth picking up charge?
Whats the cure?
With what did you verify the existence of a voltage? If it was a proximity tester or a 'neon' screwdriver they are inherently unreliable.
Edited:
Pop up to the high street with £8 in your pocket and buy a multimeter.
Neon screwdrivers are not, as dingbat has said, to be relied upon.
If you have any concerns over that circuit then either hire the services of a competant electrician or if you feel confident buy yourself a multimeter, read up on its use, and retest the voltages on the circuit.Again only do the latter if you feel confident.
Appreciate the need for better equipment
But how does a neon indicate if there is no charge?
A neon will indicate only a few volts on a wire if the voltage is there because of inductive/capacitive coupling (other live/current carrying cables laying in close proximity to isolated cables - especially on long runs)
This apparent voltage would not be enough to feel if you touched it or to power anything but the neon needs only a few milliamps to work.Please DO NOT rely on a neon screwdriver - especially to confirm if a circuit is dead!!!
