Why?I'm going to end up with about 6 in a new kitchen
Are you in England or Wales?What are teh rules about putting these into cupboards and has anyone got any clever tips?
It's allowable, but what on earth is the point?What's are the rules on having one FCU feed a double unswitched socket that then feeds two appliances (e.g. dishwasher and washing machine). Presumably this is allowable?
If you're using fused plugs on the appliances then why have FCUs before the sockets?
When you applied for Building Regulations approval, what say would be the way you would comply with Part P?I'm in England
If you're going to put them in cupboards, where they'll be behind tins of beans, boxes of cornflakes, pans, plates etc then they aren't really accessible.From what I've read on these forums the regs say that appliances that are built in must have easily accessible switches to isolate the supply in case of fault etc.
If you put the sockets where you would put your FCUs then you've provided the same degree of compliance.For built in microwaves, fridge/freezer, w/m and d/w I'd love to just plus them into sockets behind the items, but my understanding is that this wouldn't satisfy regulations.
Just use switches. If you use a grid system they won't take up much room, you can get all sorts of finishes and you can get engraved switch modules. If you want to keep the fuses accessible then you can also use fuse modules and supply the appliances via flex outlets or 15A BS 546 sockets.THerefore I'm looking at ways to provide a switch (if necessary) without ending up with 6 FCUs.
There is no need to provide individual isolators, Just provide isolators for the whole circuit/circuits.
