Loft conversion and regs
24 May 2012
Essex
I am looking to convert the loft with a dorma etc.
Do I have to have landing and fire doors? Or is there any why I can have the stairs just going directly into the loft with a balustrade?
I am happy to call it a loft and not a bedroom etc!!
You must have a fire door, it can be at the bottom of the stairs though so you can just have the stair arriving at loft level.
If you are complying with Building Regs then you must have a door there is no workaround. Even if you don't use it as a bedroom the next occupants will.
If you fit a stair then it will be assumed that you (or the next occupant) will use it as a bedroom and that will trigger the need for complying with Building Regulations. If no permanent stair is fitted then no need for Regs.
So does a drop down stair count as permanent?
But then there is no real money saved!!
I am just trying to think of a way of getting the loft more usable without doing it all at once...as the that comes at a high price tag!!
A drop down stair is effectively a loft ladder so that is not permanent so that would be permitted and would avoid the requirement for getting approval. Note anything structural you do in the loft must comply and be approved irrespective of whether it is a full blown stair conversion or not.
