Loft conversion shower blocked-what’s safe?
2 Nov 2009
London
Hi all, hope someone can advise-the shower in the loft conversion isn’t draining properly (just v slow, clearly clogged up somewhere).
I want to avoid chemical unblockers (assume not ideal for loft plumbing) and the baking soda/vinegar/boiling water trick has helped downstairs before.
Is this likely to be safe with loft conversion plumbing? There is a macerater (which I assume is just for toilet and nothing to do with shower) which I know I can’t use certain chemicals in so a bit nervous to try.
Thanks all.
Or a power/pump plunger and then there's a wet vac. Presume there isn't any access to the waste run for rodding?
