    Dismiss Notice
Loft Conversion With An Open Plan Ground Floor Possible?
Discussion in 'Floors, Stairs and Lofts' started by jagillham, 15 Jan 2013.
  1. jagillham
    jagillham
    1 Oct 2012
    275
    Thanks Received:
    8
    Kent
    Country:
    Can anybody offer some advise on how (if it is even possible) I can convert the loft into a 3rd bedroom, when the ground floor is open plan? Reading through the building regulations it would seem this could be problematic in terms of the fire parts?
    The ground floor has had all the internal walls removed as you can see on the plans below.
    The loft spreads over the main part of the house (7200mm x 3800mm) only.
    I will get a proper set of plans made up if this is possible, I'm just looking for somewhere to start from at the moment.
    Thanks in advance :D
    [​IMG]
    [​IMG]
  2. Chri5
    Chri5
    19 Jan 2007
    4,289
    Thanks Received:
    391
    London
    Country:
    I think your issue is all to do with the adjusted ground floor structure, the steel used to replace the centre wall was designed against the loading for the 1st floor layout.
    I'd imagine the loft is viable subject to full steel framing and calcs that include the overall building loads including the ground floor support.
  3. jagillham
    jagillham
    1 Oct 2012
    275
    Thanks Received:
    8
    Kent
    Country:
    Structually we should be OK. This was a "2 up 2 down" before, so in the middle of the big room is 2 steel beams which would have been the walls either side of the staircase. Upstairs one wall was removed so the void where the stairs used to come up could become part of the smaller bedroom and landing. The steel beam upstairs is over spec'd as we were considering the conversion at the time. It is something like 203 x 203.
  4. freddiemercurystwin
    freddiemercurystwin
    21 Jan 2007
    18,517
    Thanks Received:
    2,028
    Devon
    Country:
  5. jagillham
    jagillham
    1 Oct 2012
    275
    Thanks Received:
    8
    Kent
    Country:
    Thank for the link(s), I had come across a couple of those threads already as it happens. I was rather hoping with a floor plan somebody might spot something I didn't, because going down the sprinkler route is likely to tip the balance between converting or moving.
    How would I go about finding out if just the wired alarms would be acceptable? Will the BCO just tell me, or is it a case of submitting plans and waiting for a yay/nay?
    Also, has anybody had a domestic sprinkler installed recently or knows the rough cost?
  6. freddiemercurystwin
    freddiemercurystwin
    21 Jan 2007
    18,517
    Thanks Received:
    2,028
    Devon
    Country:
    Phone your Local Building Control and ask to speak with the actual inspector who deals with your area, with a bit of luck he may offer to pop out or a visit to discuss the options. You can talk to some Private Inspectors (ie not LA) too they may be a little more relaxed.
    Expect to be paying around £2-3K for sprinklers. but you may get away with a living room only system.
    Forget about the structure until you establish if the layout is a show stopper.
    • Thanks Thanks x 1
  7. DIYnot Local
    3 Sep 2019
    Country:
  8. Sponsored Links
Loading...
Share This Page
