Loft floor supporting beam
27 Jun 2013
London
I found the sites detailing required sizes of floor joists for MxM size of rooms; but is there similar for supporting these beams in the middle, as in front to back of house is 7m, floor joists are each 4m and meet across a central beam in the middle where the width is 4m.
So width 4m, length 7m divided in two by a supporting beam.
(Which currently is wooden about 6x4, as part of the dividing wall downstairs)
Why do you need a middle beam if you've already got a dividing wall there, or have I misunderstood?
The dividing wall on the floor below seems to be mainly hollow, plaster & lathe. The beam in question seems original part of that wall.
There might be structural vertical support to the beam hidden in the wall, its edwardian I dont know if they did that. But basically I think the front and back loft floor joists are relying on that beam.
As well as that 6x4 beam, some of the load is presumably transmitted to whatever is supporting the partition, via the studwork.
