We would like to board out our loft for storage, but it's currently got a huge chunk of rockwool covering all of the joists. I'm aware you can get risers for the joists, but we're a bit limited in height so I've started looking at replacing all the rockwool with celotex, so I can just board over at the joist level.
I'd like to try and comply with the current building regs, so wondered if it's acceptable to put 100mm of celotex in between the floor joists and then do a suitable thickness in between the rafters as well? The celotex calculator seems to suggest I'd need a full 200mm in one chunk to get to a U of 0.16, but also suggests that if I was to go over the joists in a separate layer I could get away with 50mm extra, so 150mm in total.
Elsewhere I've seen the total requirement being 175mm for celotex.
Is it acceptable to split the insulation up like we'd like?
Cheers,
David
Cheers,
David
