Loft insulation please
3 May 2018
hi all, just had roof done breathable felt concrete Marley pan tile
I need to insulate now. Detached bungalow on floorboards, from what
I've read, 170mm then 100mm on top is the correct or would 170mm
Be enough....? Thanks
Cheers....will need check, so if say rafters 100mm deep then its 100mm infill then 100mm
On top or 170mm....could I get away with just the infill of rafters to save costs would it
Be adequate
Rafters 100mm deep need 200sqm to do the job....she doesn't
Want to pay for cost of 100mm on bottom and 200mm on top
So do I just put the 100mm down or put 170 or 200 down she
Only wants 1 layer to keep costs down ?.
Why wickes, plenty cheaper , bought mine cheap on Facebook.
Have 450mm in my loft , false economy to skimp on insulation .
Plus if you've been good and notified Building Control about your roof replacement they'll want to see 300mm up there unless there's a very good reason (cost of rockwool isn't a very good reason). Matter of interest, what was on the roof before- slates or tiles? (If slates then your concrete tiles may be a bit heavy for the rafters)
