Loft Insulation width
26 Jun 2008
Surrey
Hi, I am going to lay some more loft insulation over the top of existing Vermiculite. The Vermiculite is about 2in and the rafters are 4in. I intend to lay some 2in timber directly on top of each rafter to create a 4in gap, lay 4in loft insulation in this (to make a total of 6 in) and then board the loft over it all.
My question is that the space between the rafters is 35 cm and all of the loft insulation for sale seems to be either 40cm or 60cm.
Can i squeeze 40cm loft insulation in this gap? Something tells me this is not a good idea as it needs to 'breathe' or is it possible to cut it how you like? I was planning to use the 'sealed in a bag' stuff but assume this is out of the question as it needs to be cut.
Any advice/opinion gratefully received.
yes go for it , no problem at all with the insulation but the boarding out could be. Light loading only :wink:
thanks for the reply. So its OK to squeeze the insulation into the gap.
Its only for boxes & suitcases etc so will ensure the load is light
