Evening all, and Happy New year ! I've got a bit of a dilemma with my loft insulation and would welcome suggestions.
My House is a late 70's build and the loft members are only 70mm deep. At present there's some blown insulation in there, but it's practically non-existent where there has been traffic.
What I am keen to do is lay insulation so that I end up with a warm loft and can set up a railway in there (lack of space elsewhere!). I had boarded some of the loft a few years back with some 100mm thick mineral wool squeezed under rafters with boarding over, but aside from the fact that I'm not sure I can still get 100mm roll insulation it's clearly not doing it much good being compressed.
The other issue is insulating under the rafters. There are only 70mm deep, so allowing the 50mm gap means I've got 20mm, therefore any sheet insulation would have to go over the rafters unless 20mm polystyrene is enough!
Would it be good enough therefore to put a thinner layer of insulation at ceiling level and another at rafter level, or should I be looking to beef up the ceiling insulation to current standards and put some token insulation under the rafters. Would the latter make the loft usable as the heat from the house would be very reduced?
Any suggestions gratefully received. Oh - I'm on a tight budget too, as if it wasn't confusing enough! Thanks in advance
