Guys,
Another question, I'm thinking of drilling all the holes for the cable runs on the top floor and getting the cable laid in advance of project re-wire but am worried about the type of cable I need to use.
Im going to be using method 101, clipped to the joists when I am running the cable in the direction of the joist however when I am putting the cable through a joist the reg's state 5cm from either the ceiling or the floor, whichever applies.
So, 5 cm from the ceiling means that when I lay the new insulation ontop of what is already there there will be more than 100mm of insulation surrounding the wires as they pass through the joists (hope this still makes sense) I'm wanting to know the best solution to the problem or am
I worrying about nothing?
I stepped the size of the cable up due to the insulation being laid after the re-wire as is stated in the reg's but am not sure by how much I should de-rate the wire for when it is passing through the joist and the middle of the insulation.
Any help would be much appreciated as always.
Also, do the majority of bathroom fans run off 1.5mm wire or should I be using something bigger to power it from, say, the upstairs ring main?
Thanks to all you helpful people in advance.
Phil
Phil
