Hi
I’m looking to replace the insulation in my loft and put new boarding across the central span.
My house (uk, 1999 build) has 75mm joists which is giving me a headache. I originally thought i would do:
- 75mm insulation throughout
- perpendicular battens with struts to raise floor in central span (to second layer insulation + 50mm gap)
- 170mm insulation in central span (because the pitch is quite shallow)
- 200mm insulation outside central span
This would result in 245mm in the boarded area and 275mm elsewhere
But I’m struggling to find 75mm floor insulation.
I’m unsure how to proceed and would be interested to hear how others would approach, ie
- battens to raise existing joists to 100mm and then proceed as above, but with 100mm and 170mm insulation
- loft legs/raisers rather than the perpendicular battens (this has always felt a less robust option to me), which would also allow 100mm and 170mm insulation
- use 75mm acoustic roll as the first layer (but this isn’t designed for ceiling level and presumably has lower thermal performance)
Grateful for thoughts, I guess I’m asking is acoustic roll ok, and if not would you opt for raised joists and perpendicular battens or loft legs.
Cheers
Cheers
