- Joined
- 27 Sep 2016
- Messages
- 6,216
- Reaction score
- 714
- Country
Hi, was looking for some advice on joist hangers.
Im preparing the opening for my double winder loft staircase.
Im hoing to be trimming the openig using 75mm wide x 200mm deep c24 joists. So the width of the joists bolted together will be 150mm wide x 200mm deep.
Where the joists fit to the wall Im going to use timber to masonary steel joist hangers.
Ive seen so.e simpsons strong ties that are expensive, about £35 each.
However ive found these which are a lot cheaper. Would these be suitable for trimming a staircase opening?
https://chandlermaterials.co.uk/joint-hanger-timber-to-brick-sph-150-x-200mm.html
Thanks in advance
Thanks in advance
