Loftbox/Triplexer question
6 May 2013
Hi all,
I got my self a loft box to transfer Radio, DAB and TV to some rooms. In some rooms I require only Radio/Dab, is it sufficient if I just put a single Outlet or do I need to fit a Triplexer outlet?
Many Thanks.
I thought those modules had filters built into them so that they pass the appropriate frequencies to the connections. If this is the case then you need a module/outlet that will output the Radio/DAB signal and filter all the rest.
But the tuner in the radio will filter the rest anyway so in all probability a single socket will do.
