Hi. I have ordered a log cabin (Finnforest Valko) that arrives next week. It comes with a pitched T&G roof and roofing shingles (which from the instructions look like strips of felt that are overlapped and designed to look like tiles). I have two questions that are hopefully easy and quick to answer:
1. Can I put a membrane on the outside of the T&G roof under the roofing shingles to help avoid leaks. I already have a role of the blue plastic DPM. Can I use this or does it have to be a breathable membrane?
2. On the inside when you look up you see the pitched roof. There is no flat ceiling and loft space. I want to insulate the ceiling and was planning on doing this like the walls using a solution recommended in the Bulding forums:
Cabin wall
Breathable Membrane
Insulation
Vapour barrier (i.e. blue plastic DPM)
platerboard
Firstly, is this the best way to insulate the ceiling. Secondly, do I need the breathable membrane (especially if one is on the outside)?
Thanks in advance for any help offered.
Cabin wall
Breathable Membrane
Insulation
platerboard
