Long Flue
24 Feb 2004
Does anybody know if there is a manufacturer producing a combi boiler which allows a long flue run. I have to install a combi boiler in a flat with the nearest external wall being about 10m away, cant go vertically so have to take it off the top of the boiler, bend 90 & run 10m flue length to the outside wall. Having trouble finding a combi boiler which has this capability.
You can get twin tubes that may give you long run.
Using the larger diameter concentric flue pipe, Vaillant ecoMAX boilers can have a maximum flue length of between 13 and 30 metres (dependant on the boiler model). You can download their flue installation instructions from HERE.
Other manufacturers may offer similar solutions.
