Hi
I'm in the Knightswood area of Glasgow
can anyone recommend a Local engineer to service a Vokera Unica HE
also Baxi Bermuda Gas Fire.
We had the Vokera installed last April it's running Ok. but sometimes notice the
Hot Water temp is a bit lower than usual. Don't know if a service might fix this or point to what may be causing the low temp ?
I'm a bit concerned about the Gas fire it was in the property when we moved in last year, according to the owner it has been serviced annually it works but have been noticiing that if it's on for some time their is a smell coming off it hard to explain gives you a headache after a while.
So if anyone could have a look would be most gratefull.
The alternative would be to take out a Homecare Contract with Scottish Gas which I'm trying to avoid unless anyone can recommend them
Ian [/code]
Ian [/code]
