Loovent 01 Mk2
15 Nov 2015
Hello,
New to forum but came across and old thread and page advised to start a new one.
Existing 01 mk1 fan never worked when I bought house, just installed a new mk11 version and all I had to do was extend the loom as shown in manual.
Problem is I turned power back on and switched cloakroom light on and fan powered up so I turned off light and then fan stopped after just 2 minutes. Once fan had stopped my LED bulb in the room started flashing.
This is when I came across the old thread saying low energy bulbs cause something to happen, so I removed bulb and put in standard 60 watt bulb and now fan doesn't work.
Still have permanent live to fan and no fuses tripped.
Have I broke it already??
Thank you in advance for any assistance.
Oops,
Looks like I've found the reason.
The small timer pack that slides on and off is a little temperamental, given it a good wiggle and all is fine.
Not sure it should've needed a good wiggle though.
Cheers Mark.
