Hi
having a bit of fun (not) in trying to find out why the pressure on my Alpha Ocean 240E boiler constantly falls (needs topping up when heating is on every 20 mins).
It does not fall as much when it is set on DHW, but nevertheless still falls.
I have checked all the pipes / carpets for signs of a leak but everything appears dry, also checked the boilers outside vent to see if that is dripping, but no signs there.
A boiler man has called and changed the following parts (we were having problems with DHW only hot when heating was on);
DHW Heat Exchanger
Flow Switch
Thermister
Diverter Valve
We now have hot water when heating off, but the problem with the constantly dropping of pressure is still there!!!
I have even isolated the inlet & outlet valves (beneath the boiler) of the central heating to see if it is on the boiler side or CH side. Doing this still dropped the pressure although at the same rate as when the heating is switched off (ie several hours before a topup is required)
There are no visible signs of water leaking from underneath the boiler, but my concerns are where is all this water going that I'm filling up each day?
Is there somthing else within the boiler that is faulty and allowing water to escape to a drain (not that I can see any pipes leading to a drain)
To give a little more background on the building;
It is a single storey (Bungalow) with no pipeworks in the loft space.
It is about 15 years old with a concrete floor, however the builders left a channel running on the inside of the floorspace with a plywood inspection cover for the pipeworks. This I have had up completely around the house and the channel is bone dry?
As I mentioned earlier we did have a problem wherby the boiler would fire up when turning on a hot tap (when heating was off) but no hot water just cold to luke warm. When heating was on we had occaisional hot water.
Could the fact that the boiler was still firing up have damaged something which is venting out the wall as steam? Expansion vessel for example?
The boiler man has suggested we put in some dye to see where the leak is, however as the pipework channel is dry I fail to see how this will help?
Any help advice appreciated
The boiler is about 5 years old
Regards
DHW Heat Exchanger
Flow Switch
Thermister
Diverter Valve
Regards
