Loss of pressure - Blocked PRV?
20 Jun 2010
Hertfordshire
Hi Folks,
First post here so be kind....
Recently my neighbour replaced the mains pipe from the street to his house. Around the same time, I have lost pressure in my house.
I have a lot of flow, same as usual, but no pressure. (If that makes sense?) I can block the tap with my thumb without much of a fight, before this was not possible. The sprinkler would normally reach about 10-12ft in the air, it now barely musters 4.
If you block a tap or hose with your thumb, when you let go there is a "burst" of water and then it reduces.
I've been told this could be a blocked cartridge in the pressure reducing valve. Where would this be situated? I have found the main tap in the house but that is all there is - a tap. Nothing else. Right after the tap there is a T for the washing machine so I doubt it would be downstream of this. Would it be outside? Is there a "normal" place it is put?
My house is about 50-60 years old and to my knowledge, has had no plumbing work done on it.
Thanks in advance
Cheers,
Crispin
Umless your mains is very high pressure you wouldn't normally have a PRV on the mains.
SOunds like you have a blockage in the "communication" pipe from the road. Call your water provider, but it would be difficult to shift it
After recent Thames water work on my neighbours supply I have also lost pressure...they've ******ed it up somewhere...
Thanks for the answers fellas. How would a blockage still allow normal flow but poor pressure? i.e. nothing on the end of the hose and it's fine. Well, maybe slightly down.
Cheers,
Crispin
